You can do this with Cloud Authentication and Policy, which is under the Global View, then Security and Authentication and policy. There you can create device policies that point assign a role depending on the client tag ([Mobile & Gadgets]). When you have done that, use Cloud Auth as authentication server for your network.
The VLAN assignment roles are AP 'local significant', so that doesn't have access to the profiling information in Central unless you link it through Cloud Auth (or ClearPass).
Original Message:
Sent: Oct 29, 2024 07:18 AM
Subject: Assign Dynamic VLAN based on Device Category
Hi all,
I am trying to make my SSID push smartdevices to a seperate vlan with wifi.
Ik found the Dynamic VLAN options, but I cant find the option to select device type as a value.
This 1 one of the devices
As you can see, central puts it in "category" "smartdevice"
But i an not sure what the right option is under the Dynamic VLAN assignment to use this value as a reference
I hope anyone here has the answer ;)
Kind regards,
Wouter
