Network Management
Assign Multiple VLAN IDs to Single SSID(WLAN) in Aruba 9240 Hardware Controller
  • 1.  Assign Multiple VLAN IDs to Single SSID(WLAN) in Aruba 9240 Hardware Controller
    Posted Sep 22, 2023 01:44 AM
    Dear Friends,
    We are already deploy Aruba H/W Mobility Controller in standalone mode. In that case we have a requirement to broadcast single common SSID within the entire premises.
    • Now we already create multiple AP-Group and APs are already assign to the relevant groups.
    • Already Create SSID as well.
    How we can we assign multiple VLAN IDs to Single SSID already we created.
    We are using Aruba 9240 H/W Mobility Controller
    DhanushkaH
  • 2.  RE: Assign Multiple VLAN IDs to Single SSID(WLAN) in Aruba 9240 Hardware Controller
    Posted Sep 25, 2023 11:04 AM
    Based on what would you like to assign the VLAN to different users?
    Just based on your description it can mean multiple things and the answer probably is yes but the how depends.
    It may be best to work with your Aruba partner and discuss the actual request and what you like to achieve and from there explore how to configure that.
