Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
This thread has been viewed 170 times
  • 1.  Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Feb 29, 2016 07:10 PM
    Hi
    Im trying to get Clearpass return HP-Egress-VLANID attribute to indicate a TAGGED VLAN association for the client device.
    According to RFC this value is in bits- http://wiki.freeradius.org/vendor/HP#procurve-port-authentication-special-features_dynamic-vlan-assignment_rfc-4675-multiple-tagged-untagged-vlan-assignment
    ClearPass only accepts unsigned integer.. as indicated in its below error message.
    Can someone guide me on how to set this attribute to return a vlan-301 as TAGGED?
    Ram
  • 2.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Feb 29, 2016 07:45 PM
    Got it working.. simply converted HEX into decimal value:
    HEX 3100012D = DECIMAL 822083885
    CP-2530(config)# sh port-access mac-based 23 client det
    Port Access MAC-Based Client Status Detailed
    Client Base Details :
    Port : 23
    Client Status : authenticated Session Time : 236 seconds
    MAC Address : 00e0bb-22b814 Session Timeout : 0 seconds
    IP : n/a
    Access Policy Details :
    COS Map : Not Defined In Limit Kbps : Not Set
    Untagged VLAN : Not Set
    Tagged VLANs : 301
    Port Mode : 1000FDx
    RADIUS ACL List : No Radius ACL List
    Regards
    Ram
  • 3.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Jun 09, 2016 11:50 AM
    Not working for me...
    I can use decimal value and that VSA to send untagged vlan.. but doesn't seem to be working for tagged...  I think it's the switch.
    It'd be great to get some radius debug from HPE OS.. do you have any clues ?
  • 4.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Jun 10, 2016 04:12 AM
    In retrospect.. mine's not working for untagged either...
  • 5.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Jun 10, 2016 04:24 AM
    I'm doing this on a brand new 2530, running Software revision  : YB.16.01.000..
    FYI.. if anyone wants to pipe in and provide some feedback..
  • 6.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Sep 01, 2016 06:19 AM
    Instead of the HP-Egress-VLANID you can also use now "HPE-Egress-VLAN-Name = 1VOICE".
    Use "1" in front of the Vlan name if you want to use a tag en use "2" for untagging.
  • 7.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Sep 01, 2016 09:21 PM
    I never commented back on this thread after I raised it..
    I ended up finding out that I think the switch software needs to support RFC4675 to be able to support parsing RADIUS attribute tagged vlan id.
    https://tools.ietf.org/html/rfc4675.
    That was my issue at the time.. The HPE switch model explicitly lacked RFC4675 support, where as other models higher up in the portfolio did support it.
  • 8.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Aka, the 2530 does not support RFC4675.
  • 9.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted May 10, 2018 07:48 AM
    Where did you find the info that the 2530's don't support RFC4675?  Is there a list somewhere of switches that do and don't support it?  I have a variety of switch models in my environmnet and I'm trying to figure out how many of them this will actually work for.
  • 10.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted May 10, 2018 09:16 PM
    That was two years ago.. maybe with some re-invigoration .. new OS release they might.. but pretty sure they were trying to clamp down on low end models doing everything.. just purely to push people up the footprint/form factor stack.  I just searched the datasheet online.
    https://support.hpe.com/hpesc/public/home/productSelector?psiTask=manuals&sp4ts.oid=5333803 and string searched my way through the 'support protocols' section for '4675'
  • 11.  RE: Assign Tagged VLAN via Radius attribute using "HP-Egress-VLANID" parameter
    Posted Dec 17, 2019 02:21 PM
    old thread but just wanted to share that some time ago i had tagged VLAN and non tagged VLAN (voice and data setup) work on both 2620 and 2530 (firmware RA.15.10.0013).
    [edit] method mentioned by networkingsire used.
