Developer
  • 1.  Assistance in automating token creation and renewal?
    Posted Sep 30, 2024 11:00 AM
    We are getting started with using the api to do some automation, but we're having issues with the token acquisition process.  I have a client ID (personal and system) and can make an access token in the web UI, then copy and paste it into my code and execute functions, but when I go to request the initial token or renew it I get an error "invalid client_ID".  I have to guess I have a syntax problem, but I have tried it using REST in PowerShell and using pycentral and I'm seeing the same thing.  I am pretty sure my API App is fine because, like I said, I can download and use an access token from the web GUI, but if I try to automate that it fails.  Below is some sample code to show what I'm doing, so if anything jumps out that I'm doing wrong I would appreciate any feedback.
    PowerShell
    $CLIENT_ID="#######################"
    $BASE_URL="apigw-uswest4.central.arubanetworks.com"
    $API_URI="https://"+$BASE_URL+"/oauth2/authorize/central/api/login?client_id="+$CLIENT_ID
    $headers = @{
        "accept" = "application/json"
    $body = @{
        "username" = "#########@###.com"
        "password" = "#################"
    } | convertto-json
    Invoke-RestMethod -Method POST -ContentType 'application/json' -Headers $headers -Body $body -uri $API_URI
    Invoke-RestMethod : {"extra":null,"message":"Invalid client ID"}
    Python
    >>> from pycentral.base import ArubaCentralBase
    >>> from pprint import pprint
    >>> central_info = {
    ...     "username": "#######@#####.com",
    ...     "password": "#################",
    ...     "client_id": "#################",
    ...     "client_secret": "#################",
    ...     "customer_id": "################",
    ...     "base_url": "https://app1-apigw.central.arubanetworks.com"
    >>> ssl_verify = True
    >>> central = ArubaCentralBase(central_info=central_info, token_store=None, ssl_verify=ssl_verify)
    2024-09-27 08:01:52 - ARUBA_BASE - ERROR - Unable to load token from storage with error .. [Errno 2] No such file or directory: 'C:\\Working\\Python.ArubaCentral\\temp\\tok_800aaf4c826e446897a88f0d70845122_jtmgv3wP9f0RWeZS9j0uAZH6J2aK76Vf.json'
    2024-09-27 08:01:52 - ARUBA_BASE - INFO - Attempting to create new token from Aruba Central
    2024-09-27 08:01:53 - ARUBA_BASE - ERROR - OAUTH2.0 Step1 login API call failed with response {'code': 400, 'msg': '{"extra":null,"message":"Invalid client ID"}\n'}
  • 2.  RE: Assistance in automating token creation and renewal?
    Posted Sep 30, 2024 03:47 PM
    Edited by Tiffany.Chiapuzio-Wong Sep 30, 2024 03:47 PM
    Hi @joseph.gullo.pcci! Just wanted to verify you're following these instructions for retrieving the Client ID & Secret:
    https://developer.arubanetworks.com/hpe-aruba-networking-central/docs/api-gateway-creating-application-token
    Also I noticed between the two examples you're using two different API gateways, in the first it's
    and in the second it's
    Which cluster are you using?
    Ti Chiapuzio-Wong (they/them)
    HPE Aruba Networking
  • 3.  RE: Assistance in automating token creation and renewal?
    Posted Sep 30, 2024 04:03 PM
    That was the clue I needed, I didn't realize the clusters weren't shared and that our account only exists on one, Thank you!
  • 4.  RE: Assistance in automating token creation and renewal?
    Posted Sep 30, 2024 04:07 PM
    Of course! Glad it was a simple fix! Happy automating!! :)
