  • 1.  Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 01, 2013 06:56 AM
    I have AP 93 connected to controller 3200 in two ways .
    1) some AP are connected in campus mode
    2) Some Ap are connected in RAP(remote ) Mode over MPLS link
    Forwarding mode = Bridge for the both cases
    Question :
    When i am doing authentication with controller how much is the bandwidth  consumed by  Each AP ??
    Is it continious ?
    Please comment .
    #3200
  • 2.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 01, 2013 12:26 PM
    Answer.
    Very little and it only happens when the user is authenticating.
  • 3.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 01, 2013 02:04 PM
    Like cjoseph said is not much, 802.1x BW requirement is between 1-5k depending on the type of EAP method you are using.
  • 4.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 02, 2013 01:14 AM
    As we discuss with our Aruba partner , told that around 100kbps per Ap is required in RAP mode...
  • 5.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 02, 2013 09:14 AM
    See if this helps
  • 6.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 05, 2013 02:01 AM
    Thanks fo your page ..
    I have one more dout  suppose i have 40 user are connected to AP (Access-Point).IN RAP mode
    Whenever user trying to connect the SSID all authentication & 802.1x control packet goes to controller through MPLS .
    Now can you provide me the bandwidth consumed by All 40 user between Access-Point & Controller .(Only Authentication & Controlling) anyway in RAP mode your normal traffic never goes to controller.
    Waiting for your reply
    Sambhaji
  • 7.  RE: Authentication Packet ..(Bandwidth required for Auth packet in Bridge & Tunnel mode)
    Posted Jul 08, 2013 01:04 AM
    This Information is regarding The RAP mode
