  • 1.  Authentication Timers Disabled?
    Posted Oct 26, 2012 07:21 PM
    I have 2 Aruba Contollers, a 3400 (master) and a 3200 (local) both running 5.0.4.1.
    I can change the Authentication Timers on the 3400 through the web interface and console but the options are greyed out/disabled on the 3200. The settings don't appear to be synching.
    Is there a way to force the timer settings to sync or some way of manually setting them on the 3200?
    #3200
    #3400
  • 2.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:28 PM
    Which timers are you referring to?
  • 3.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:38 PM
    All of them under Configuration/ Security/Authentication/ Advanced - Authentication Timers.
    They all appear locked/greyed out with different values to those that I've set on the master.
  • 4.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:43 PM
    They can only be set on the master.  They are read-only on a local controller.
    To check on the commandline to see if the master and local are in synch type: "show switches" on the master.
    To check in the GUI go to Monitoring> All WLAN controllers.
    Also go to the configuration tab on the master and click on save configuration and check again to make sure both controllers are synchronized.
  • 5.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:42 PM
    User Idle Timeout is set to 7200 secs on the 3400. It is set at 300 on the 3200 and cannot be changed.
  • 6.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:48 PM
    Monitoring> All WLAN controllers. Shows UPDATE SUCCESSFUL and a config sync time of 10secs.
    Show switches returns the same info.
  • 7.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 07:55 PM
    You might be running into a display issue.
    If you can ssh to both controllers, type "show aaa timers" on both controllers to determine the correct settings.
  • 8.  RE: Authentication Timers Disabled?
    Posted Oct 26, 2012 08:08 PM
    Thank you cjoseph.
    This is just a display issue in the web gui ... and some mis information from a particular user.
    The CLI on the local controller returns the correct values that have been set and sync'd from the master.
    Thanks again. The quick response is very much appreciated.
