Hello, I am having issues with the auto-join setting and wanted to see if anyone else has had this isuse. We are using Airwave IGC for all IAP cluster management. Airwave is on 8.2.7. We are seeing this issue on both the old 6.5.1.5 and the new 8.3.0.3 IAP firmware.
What happens is when we disable auto-join in the Group>System settings, some or all of access points in the cluster will start getting blocked. I have seen it where only the VC was active and all other access points were blocked. This is on existing clusters that were working fine, not new access points that are not in the cluster already.
