Wired Intelligent Edge
  • 1.  Avaya to Aruba VLAN Problems
    Posted 26 days ago
    Hi
    i have Problem with configuring a VLAN from an Avaya 3549GTS switch to Aruba 6300.
    On Avaya 3 VLANs. 1-default, 2, 3.
    vlan create 2 type port
    vlan create 3 type port voice-vlan
    vlan ports 47-48 tagging tagAll
    vlan configcontrol flexible
    vlan members 1 NONE
    vlan members 2 25-35,47-48
    vlan members 3 1-24,47-48
    vlan ports 1-24 pvid 3
    vlan ports 25-46 pvid 2
    vlan ports 47-48 pvid 3
    no auto pvid
    On Aruba just
    interface 1/1/51
    vlan trunk native 3
    vlan trunk allowed 2,3
    With this preference 3 VLAN can to Aruba. But 2 can't.
    If i set on AVAYA
    vlan ports 47-48 pvid 2
    both VLAN can't go to Aruba.
    Can u help me?
  • 2.  RE: Avaya to Aruba VLAN Problems
    Posted 26 days ago
    did you check this thread which is related to migrating from Avaya switch and Aruba-CX
    https://community.arubanetworks.com/discussion/migration-from-avaya-switches-to-aruba-cx-switches
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: Avaya to Aruba VLAN Problems
    Posted 26 days ago
    I don´t which interface you use on the Avaya to connect to the Aruba switch.
    This config on the Aruba switch port means that an untagged VLAN 3 is allowed and a tagged VLAN 2.
    interface 1/1/51
    vlan trunk native 3
    If you only want to allow tagged VLANs 2 and 3 on the Aruba switch you can configure this, VLAN 1 is the default native VLAN but any untagged traffic coming into the port is not allowed because it is not in the allowed list.
    interface 1/1/51
    vlan trunk native 1
