Sometimes the solution is not that complex as one think. Good to hear that it was just a bad ISO download.
Original Message:
Sent: Nov 01, 2024 08:26 AM
Subject: AW 8.3.0.0 clean install on nutanix does not go Step 4
it turns out bad ISO ?!?!. same 8.3.0.0 iso did not work on our lab KVM hypervisor either.
had to download 8.3.0.3 iso and this one worked flawless, including on nutanix.
i read that i could do direct migrate to 8.3.0.3, if i do prior 8.2.15.2, so that'll do aswell
Original Message:
Sent: Nov 01, 2024 04:43 AM
Nutanix is not official supported as Supervisor
AirWave supports installation on AirWave appliances, VMware, Hyper-V and KVM (The recommended OS is Red Hat Enterprise Linux 8 (64-bit)). Support for bare metal installation is provided on a best-effort basis.
Source: Installation Guide - https://www.arubanetworks.com/techdocs/AirWave/8304/AirWave_8.3.0.4_Installation_Guide.pdf
Have you tried to click "Yes" on Step 4?
Original Message:
Sent: Nov 01, 2024 04:20 AM
hi,
base new "step 1: install aw" install (we're migrating from old centos 8.2.15.1, but i'm preparing a new vm atm to transfer my database later) seemed to fine, i can log in using default username and password, it shows me "step 2 change time/zone", then step 3 "checking for previous installs", entering "n" it doesn not go to step 4 creating recovery user and instead returns to user login prompt. If i log in again, it's the same step 1 time/zone stuff.
any pointers?
