Working on 5930 switches (using comware 7), i have a bridge aggregation to connect 2 sites:
interface Bridge-Aggregation2
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 10
vlan mapping 5 translated-vlan 10
link-aggregation mode dynamic
mad enable
undo stp enable
stp root-protection
I've noticed that if i don't respect the same bridge aggregation group on both ends, the vlan remapping function is not working (so no communication between the 2 sites)
If i removed the vlan remapping command, then the bagg is working fine.
So my question is quite simple :)
Is it mandatory to use same bridge aggregation group on both ends when we are using advance commands like qos / vlan remapping on it?
I'm not able to find a proper explaination.
