  • 1.  band steering
    Posted Jan 21, 2016 10:21 PM
    Is HP unified wireless support band steering feature? just want dual-band capable clients direct to the 5GHz radios instead of 2.4GHz radios. which command should i use?
  • 2.  RE: band steering
    Posted Jan 26, 2016 09:36 AM
    under wlan rrm --> band-navigation enable is the command to enable band steering on the Unfied controller.
    Refer to attached document for more details on this feature.
    Attachment(s)
