Beam Spread From Aruba AP12
  • 1.  Beam Spread From Aruba AP12
    Posted Mar 20, 2023 11:04 AM
    Hi all,
    Just bought 4 AP12 units,
    I have been trying to find a diagram that indicates the wifi spread/direction,
    Can anyone help,
    Many thanks in advance
  • 2.  RE: Beam Spread From Aruba AP12
    MVP GURU
    Posted Mar 20, 2023 12:36 PM
    See the attachment.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
    Attachment(s)
    pdf
    ANTENNA PATTERN PLOTS.pdf   1.31 MB 1 version
  • 3.  RE: Beam Spread From Aruba AP12
    Posted Mar 21, 2023 05:09 AM
    Thank you for the info. Cheers
