SD-WAN
  • 1.  Best practice to connect two SDWAN fabric
    Posted May 15, 2025 06:02 AM
    Hi Team,
    My task is to create connection between two seperate SDWAN fabric managed by different Orchestrators. The only solution what I found is to create manual ipsec tunnels between for example the HUBs of the seperate fabrics.
    Do you know maybe a better solution, or this is the only one?
    Thank you!
  • 2.  RE: Best practice to connect two SDWAN fabric
    Posted May 15, 2025 08:07 AM
    Have a look here:
    https://arubanetworking.hpe.com/techdocs/sdwan/docs/orch/orchestrator/server/cloud-portal/#secondary-accounts
    If your orchestrator does not have this option then you will need to upgrade to a newer version.
    Major pain is you need to move appliances and configuration over from one Orchestrator to the other and you can't have two active Orchestrators for one account. Minor pain is you can't assign licenses from account #1 to hardware belonging to account#2.
