Best way to backup/restore endpoint data
  • 1.  Best way to backup/restore endpoint data
    Posted Sep 11, 2019 05:46 AM
    I' ve been playing with device fingerprints for a while. but never been really brave enough to make major changes to our production clearpass service in terms of fingerprint definitions. Main reason is that if you import a fingerprint definition and u get it wrong you could have thousands of device types being changed and if you're using fingerprint info in your enforcement policy that could be a lot of pain.
    I do have an enhancement request in for a "Are you really really sure.. you're going to change X number of endpoints" button to be part of the fingerprint import process just to make sure you can back out of changing entire contents of your endpoint db
    Up till now when I've been playing wtih fingerprints I've backed up the whole server config and just restored that which works but takes a while.... but not as long as actually exporting all the endpoints.
    Question, if I export all my endpoints, then make a change to a device fingerprint definition that changes 1000's of devices, if I attempt to import the exported endpoints file will it
    1). restore everything overwriting the contents there ( .o.k this is assuming I've deleted the erronious fingerprint definition and stopped the processing additional endpoints info)
    2). skip the ones that are there implying I'd have to delete the entire endpoint db and then import stuff
    Rgds
    Alex
  • 2.  RE: Best way to backup/restore endpoint data
    Posted Sep 13, 2019 06:51 AM
    So 3 attempts to import an endpoints xml file failed with just an importing.... message.
    quickest way  IS to backup the whole server and reatore it.
    Would put someting in innovate ... but any attempt to sign on fails .. site seems to be looping in a scripot somewhere AND more annoyings I can use the Aruba single signon to log into this service but not the innovate one
    something not quite right somewhere.
