Network Management
  • 1.  block duplicate gateway
    Posted May 14, 2018 03:38 AM
    how can i prevent a user from getting the IP of the default gateway or how can i allow ips, only from DHCP?
    or that this port is then locked?
    i have an aruba 2930f switch
  • 2.  RE: block duplicate gateway
    Posted May 14, 2018 04:07 AM
    Ensure the device that is providing DHCP does not offer the default gateway IP as a user IP. So exclude the IP of the default gateway from the IP address ranges being offered by the device doing DHCP.
  • 3.  RE: block duplicate gateway
    Posted May 14, 2018 04:25 AM
    I've excluded the gateway IP from DHCP :) But what can I do about it if a user specifies the gateway IP as a static IP?
