  • 1.  block mobile devices connecting to certain SSID
    Posted Apr 11, 2016 01:26 PM
    Hi
    is there anyway we could block IOS and android devices specifically connecting to a particular SSID. i have a 3600 aruba controller and it had latest version of software 6.4.3.7
    thanks
    Karthik
  • 2.  RE: block mobile devices connecting to certain SSID
    Posted Apr 11, 2016 01:35 PM
    Do you have ClearPass?
    What authentication method is in use?
    Sent from Nine<>
  • 3.  RE: block mobile devices connecting to certain SSID
    Posted Apr 11, 2016 01:37 PM
    The specific wireless is setup of computer based testing and teachers in the classroom will connect the laptops to this specific wireless. For easy access right now is open
  • 4.  RE: block mobile devices connecting to certain SSID
    Posted Apr 11, 2016 01:59 PM
    It would be easier to enable authenticaton via 802.1x.  An Open SSID does not leave you many security options that cannot be circumvented.
  • 5.  RE: block mobile devices connecting to certain SSID
    Posted Oct 11, 2017 04:08 PM
    Is device descrimination  possible with a controller based SSID?
    I know ClearPass can but hoping to achieve this without migrating the SSID to ClearPass.
