Cloud Managed Networks
  • 1.  Blocking a client on a CX switch using Aruba Central
    Posted Feb 27, 2025 07:05 PM
    Hi, we have a situation where some users are bringing VPN wireless routers, such as the GL.iNet CRETA.
    We can identify these devices in Aruba Central since they all use the OpenWRT OS.
    Is there a way to block them either by OS or MAC address at the switch level using Aruba Central?
  • 2.  RE: Blocking a client on a CX switch using Aruba Central
    Posted Feb 28, 2025 02:11 AM
    Hi.
    Yes you can. Tag those devices with your tag and then create policy to set the role for those devices.
    Create Tag with this client signature or update already existing signature for those devices.
    Create required role on switch and assign it to this tag.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 3.  RE: Blocking a client on a CX switch using Aruba Central
    Posted Mar 03, 2025 09:23 PM
    Hi Gorazd,
    Thank you for your assistance.
    Could you please provide information on how to add a Client Role in the switch? Currently, the roles I have configured on the Wireless Access Points are visible, but there are no rules for the switch.
    I have configured a role on the switch as shown below, but it does not appear:
  • 4.  RE: Blocking a client on a CX switch using Aruba Central
    Posted Mar 04, 2025 02:49 AM
    Hi Asim.
    How to configure role on switches depend on the switch model.
    For AOS-S for example: block access to subnets 192.168.0.0 and allow all others
    class ipv4 "BLOCKED_NETWORK"
      10 match ip 0.0.0.0 255.255.255.255 192.168.0.0 0.0.255.255
    class ipv4 "IP-ANY-ANY"
      10 match ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    policy user "BLOCK_INTERNAL"
      10 class ipv4 "BLOCKED_NETWORK" action deny
      20 class ipv4 "IP-ANY-ANY" action permit
    aaa authorization user-role name BLOCKED_DEVICE
       policy BLOCK_INTERNAL
       vlan-name QUARANTINE
    For AOS-CX the same example can look like:
    class ip BLOCKED_NETWORK
      match any any 192.168.0.0/255.255.0.0
    class ip ANY-ANY
      match any any any
    port-access policy BLOCK_INTERNAL
      class BLOCKED_NETWORK action drop
      class ip ANY-ANY
    port-access role BLOCKED_DEVICE
      associate policy BLOCK_INTERNAL
      vlan access name QUARANTINE
     For details and caveats please look into documentation of respected switch platform. Here are just examples without any details.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
