Wired Intelligent Edge
  • 1.  BPDU Guard snmp trap
    Posted Jan 26, 2018 09:47 AM
    Do  guys you know if the  aruba os switch sends any sort of snmp trap when that event happens
    I mean when a switch connects to a port fast that has bpdu guard enable and send me a trap that he turned off the port becuase someone tried to connect a swtich on a port fast port.
    Cheers
    Carlos
  • 2.  RE: BPDU Guard snmp trap
    Posted Feb 04, 2018 03:24 PM
    On ArubaOS-Switches this feature is called bpdu-protection. Here is how you configure it incl. enabling SNMP TRAPS:
    ProCurve Switch 5406zl(config)# spanning-tree <port-id> bpdu-protection
    ProCurve Switch 5406zl(config)# spanning-tree trap errant-bpdu
