Branch controller tunnel inside a 3rd party IPSEC tunnel
  • 1.  Branch controller tunnel inside a 3rd party IPSEC tunnel
    Posted Nov 27, 2019 12:39 AM
    I want to add a branch 7008 controller that is managed by my VMM in HQ (both running AOS 8). The Branch and HQ use a 3rd party firewall with an IPSec tunnel to connect the sites. I do not want to try and setup a tunnel from the branch controller to a VPNC in HQ.  Is is possible to setup the controller IPsec tunnel between the MD and the MM inside of a 3rd party IPsec tunnel?Capture.JPG
  • 2.  RE: Branch controller tunnel inside a 3rd party IPSEC tunnel
    Posted Nov 30, 2019 12:44 PM
    hi cb732,
    from my point of view, if there is IP connectivity between the 7008 and the MM in your HQ, they will connect as they were on the same campus.
    I do not see any problems with this setup.
    BR
    Florian
