Cloud Managed Networks
Branch Gateway IGMP Querier?
  • 1.  Branch Gateway IGMP Querier?
    Posted Sep 13, 2021 07:06 PM
    Does anyone know if it is possible to enable IP IGMP on a L3 interface of a Branch Gateway to facilitate IGMP snooping for a downstream L2 switch?
    The only option I can find is 'broadcast multicast optimization' on the VLAN configuration, but this doesn't seem to enable the querier.
    Chris Denham
  • 2.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 03:03 AM
    yes branch gateways support enabling IGMP.
    See this screenshot from the group level configuration
  • 3.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 03:29 AM
    That is very strange - I don't have that option, what Central region are you in?
    Chris Denham
  • 4.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 04:25 AM
    mine is in APAC-South1
  • 5.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 05:10 AM
    Hmmm I'm also in apac-south1 - if you create a test BGW without any other config do you get that option? (e.g. for VLAN 1)?
    Chris Denham
  • 6.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 08:16 AM
    I believe you need to have a gateway in your group and have the basics configured.
    So I suggest that you get your BGW up and running by configuring the system IP, and relevant VLAN for WAN/LAN and then enable  IGMP on your VLANs.
  • 7.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 05:59 PM
    Are you using AOS10?
    Chris Denham
  • 8.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 07:10 PM
    no they are not AOS10, they are running 8.7.0.0-2.3.01_808328
    perhaps the best thing is to talk to Rick who is based in NZ.
  • 9.  RE: Branch Gateway IGMP Querier?
    Posted Sep 14, 2021 07:16 PM
    Thanks am talking to him as we speak :)
    Chris Denham
  • 10.  RE: Branch Gateway IGMP Querier?
    Posted Sep 24, 2021 05:25 AM
    pls try  to make it under Device level
    Elouassif Abdelaziz
  • 11.  RE: Branch Gateway IGMP Querier?
    Posted Sep 24, 2021 07:17 PM
    Still not there at device level unfortunately :(
    Chris Denham
  • 12.  RE: Branch Gateway IGMP Querier?
    Posted Sep 24, 2021 07:49 PM
    What is the type of licence used ??
  • 13.  RE: Branch Gateway IGMP Querier?
    Posted Sep 24, 2021 08:31 PM
    Its a Foundation license
    Chris Denham
  • 14.  RE: Branch Gateway IGMP Querier?
    Posted Sep 27, 2021 05:20 AM
    pls check if foundation included IGMP
    Elouassif Abdelaziz
  • 15.  RE: Branch Gateway IGMP Querier?
    Posted Sep 27, 2021 04:01 PM
    Yes, the only features listed in Advanced that aren't in Foundation are:
    - SaaS Express
    - Streaming API
    Chris Denham
