Comware
  • 1.  bridge aggregation odd interfaces
    Posted Feb 09, 2016 12:32 PM
    my config: 3 esxi 6 hosts with 6 nic each. 2 hp a 5120 in IRF domain (10gbe int).
    I'd like to configure 3 nics per host in a bridge-aggregation group.
    This is what i did:
    interface Bridge-Aggregation3
    description nodo1-vmnet-dati
    port link-type trunk
    port trunk permit vlan 1 2 3 4to10
    interface GigabitEthernet1/0/8
    port link-aggregation group 3
    interface GigabitEthernet1/0/10
    interface GigabitEthernet2/0/8
    Link aggregation mode is static unless it set two interfaces in "unselected" mode.
    display link-aggregation verbose bri 3 shows 3 interfaces selected and a 3gbps channel.
    Connectivity on esxi vm is absent and networks shown by 3 virtual switch uplink are wrong.
    Am i missing something?
    Thanks.
    Nicola
  • 2.  RE: bridge aggregation odd interfaces
    Posted Feb 10, 2016 04:48 PM
    What is the corresponding config on the ESX physical interfaces and on the vSwitch?
    Your trunk config on the switch looks fine.
    You could do a "display link-aggregation summary".
  • 3.  RE: bridge aggregation odd interfaces
    Posted Feb 11, 2016 01:32 AM
    Solved, thanks for you attention.
    After "defaulting" interfaces and rebuild bridge-aggregation (in static mode) display link-aggregation summary shows the 3 interfaces in selected state.
    But still no connectivity from esxi side.
    Creating and configuring a distributed virtual switch solved the problem. I don't know if DVS speaks better lacp...
    Thanks again
    Regards
    Nicola
