Hey Brett, for these case it is best to use Central Automation Studio
Basically CAS uses API to do various tasks. For your task, once you have added your account to CAS, Once all that is setup, you can use the Device Inventory page in CAS.
From there, restrict the search to just devices without a group (via a simple checkbox) and then filter and sort to find what they want. Then click the Move To Group button and select the group.
Original Message:
Sent: Jun 15, 2023 11:53 PM
Subject: Bulk add Serial Numbers to Aruba Central Group
Hi all,
I have ~800 switches that I want to add to 4 different Template Groups before they are sent out to site. How do I achieve this without searching for the serial number one by one in the 'Device Preprovisioning' page? There are thousands of other devices already online in this network so this page so I can't filter on these devices to select them in one go.
Brett V
