  • 1.  Bulk Conversion of IAPs to Campus APs
    Posted Aug 06, 2013 05:46 PM
    Hello All,
    Is there a way to do a bulk conversion of IAPs to Campus APs?
    I have like about 70 IAPs I need to convert to Campus APs. How would you advice I should proceed?
    Do I bring up a VC first and get all other APs join the cluster? Then proceed to convert the VC to a Campus. Will the VC trigger all other IAPs to convert to Campus APs?
    Or will I have to convert them indvidually?
  • 2.  RE: Bulk Conversion of IAPs to Campus APs
    Posted Aug 06, 2013 05:54 PM
    Yep - connect all the ap's (in 64 packs or less) to the same VC - and it will convert all the ap's on the same vc to be CAP'S
    If u are using iAP93 so it's in 16 ap's per VC (just a note)
  • 3.  RE: Bulk Conversion of IAPs to Campus APs
    Posted Aug 06, 2013 05:58 PM
    I'm using IAP135s. How many APs can a IAP135 VC manage?
    Will 64 IAPs be too much?
  • 4.  RE: Bulk Conversion of IAPs to Campus APs
    Posted Aug 06, 2013 06:20 PM
    Yes,Its the max recommended.
    If u planing not to convert them and use them as IAP units also consider troughput needs,client technical demands and needs and maximum users.
  • 5.  RE: Bulk Conversion of IAPs to Campus APs
    Posted Aug 06, 2013 06:39 PM
    Thx kdisc98.
