Wired Intelligent Edge
  • 1.  BYOD Help!
    Posted Nov 28, 2016 12:31 PM
    I am looking at implementing a BYOD solution for our Sixth Form.  I have installed 4 Aerohive AP230s and will use Hive Manager Cloud Management to manage the wireless network side of the solution.
    I have the following resources:
    1 HP Switch 5406zl (J8697A) (Core)
    1 HP 2530-48G-PoEP Switch (J9772A) (Edge - Sixth Form)
    4 Aerohive AP230 Access Points
    1 Aerohive Hive Manager
    1 Microsoft Network Policy Server (RADIUS)
    1 Smoothwall UPS S8 Appliance
    The two switches are linked by a 1GB fibre connection.
    I have created 2 VLANs: VLAN 10 and VLAN 20
    VLAN 10 is named CORP_VLAN for Teachers and Staff access
    VLAN 20 is named BYOD _VLAN for BYOD traffic internet access only
    I have a RADIUS Server setup to use 802.1x Windows Authentication for both VLANs
    On the core switch B3 connects to port 49 of the Edge switch and this is the fibre uplink connection.
    The configuration of the 2 switches is as follows:
    Core Switch: VLAN 1 Default_VLAN (Primary)
    IP Address: 10.1.0.23
    SM: 255.255.0.0
    GW: 10.1.0.19
    Ports Tagged: None
    Ports Untagged: A1-A9,A11-A24,B1-B24,C1-C24
    Core Swtich: VLAN 10 CORP_VLAN
    IP Address: 10.6.0.10
    SM: 255.255.0.0
    GW: 10.1.0.19
    Ports Tagged: B3
    Ports Untagged: None
    Core Switch VLAN 20 BYOD_VLAN
    IP Address: 10.5.0.10
    SM: 255.255.0.0
    GW: 10.1.0.19
    Ports Tagged: B3
    Sixth Form Switch VLAN 1 Default_VLAN (Primary)
    IP Address: 10.1.0.197
    SM: 255.255.0.0
    GW: 10.1.0.19
    Ports Tagged: None
    Ports Untagged: 1-24  29-52
    Sixth Form Switch VLAN 10 CORP_VLAN
    SM: 255.255.0.0
    GW: No Gateway
    Ports Tagged: 49
    Ports Untagged: 25-28
    Sixth Form Switch VLAN 20 BYOD_VLAN
    SM: 255.255.0.0
    GW: No Gateway
    Ports Tagged: 49
    DHCP Config:
    Scope 10.1.0.0 (Default Scope | Default_VLAN)
    Address Pool: 10.1...0.0 - 10.1.20.254
    Router: 10.1.0.23 (Core Switch)
    DNS Servers: 10.1.0.125, 10.1.0.126
    Domain Name: acaciahighschool.local
    Scope 10.5.0.0 (BYOD_VLAN)
    Address Pool: 10.5.0.50 - 10.5.20.254
    Router: 10.5.0.10
    Scope 10.6.0.0 (CORP_VLAN)
    Address Pool: 10.6.0.50 - 10.6.20.254
    Router: 10.6.0.10
    DNS Servers: 10.1.0.125, 10.1.0.125
    Hi
    The APs are all recieving IP addresses from VLANs 10 and 20, but when probing for VLANs from the AP230s they cannot find any VLAN apart from the Default_VLANs
    My question is does the switching and routing look consistent and correct in combination with the DHCP scopes that are setup for the associated VLANs.
    I would really appreciate some expert guidance on this
  • 2.  RE: BYOD Help!
    Posted Mar 12, 2017 08:30 AM
    I think you need to look at your IP addressing first - you have some mismatches with the subnet ranges and the gateways that should be in those ranges based on what you have posted.
    eg IP Address: 10.6.0.10
    SM: 255.255.0.0
    GW: 10.1.0.19 <-- should this be 10.6.0.19?
    See http://www.subnet-calculator.com/cidr.php as a good tool for helping with IP addressing
    It also looks like the VLANs 10, 20 have the same untagged ports 25-28 - you can only have one untagged VLAN per port. One VLAN should be tagged.
