That is the thing. I have changed the reginal settings which prompts a reboot each time. I have toggled between both settings and it doesnt make a difference. Caller ID on forward remains 614-280-16XX> I will paste my entire dial plan, if you can tell me what to strip out I will and then test. DO I need to do anything in Netset under dialplan>Prestranslators?
I wrote this entire dial plan via trial and error.
/ NBX Dial Plan Configuration File
/ Generated from machine V3000 192.168.17.251 owned by Influent
/ Generated on WED NOV 04 08:45:44 2009
/ First, delete all existing dialplan information
Table Delete *
DestinationRoute Delete *
TimedRoute Delete *
PreTranslator Delete *
/ Now, create all dialplan information
/ Settings. Note: ACD ranges included in HuntGroup category.
ExtensionLength 4
ExtensionRange Telephone 3000 3777
ExtensionRange Park 7000 7099
ExtensionRange AutoAttendant 5500 5599
ExtensionRange HuntGroup 4000 4099
ExtensionRange External 6300 7999
/ The ExtensionRange External Setting MUST include the Park range.
/ If the Call Park range is outside of the ExtensionRange External,
/ the Call Park feature will not work.
ExternalSettings 8 6300 500
/ Dial Plan Tables
Table Create 1 Internal 4 Digit Extensions
/ Id Entry Digits Min Max Class Prio Route
TableEntry Create 1 1 0 1 1 Internal 0 4
TableEntry Create 1 2 1 4 4 Internal 0 0
TableEntry Create 1 4 3 4 4 Internal 0 0
TableEntry Create 1 5 4 4 4 Internal 0 0
TableEntry Create 1 6 500 3 3 Internal 0 3
TableEntry Create 1 7 55 4 4 Internal 0 3
TableEntry Create 1 8 6 4 4 Internal 0 0
TableEntry Create 1 9 7 4 4 Diagnostics 0 0
TableEntry Create 1 10 8 8 11 Local 0 1
TableEntry Create 1 11 80 2 64 Operator 0 1
TableEntry Create 1 12 801 4 64 International 0 1
TableEntry Create 1 13 81 9 12 LongDistance 0 1
TableEntry Create 1 20 8101 9 64 AlternateLong 0 1
TableEntry Create 1 21 911 3 3 Emergency 0 2
TableEntry Create 1 22 81800 12 12 TollFree 0 1
TableEntry Create 1 23 81888 12 12 TollFree 0 1
TableEntry Create 1 24 81877 12 12 TollFree 0 1
TableEntry Create 1 25 81900 12 12 Toll 0 1
TableEntry Create 1 26 81976 12 12 Toll 0 1
TableEntry Create 1 27 9911 4 4 Emergency 0 1
TableEntry Create 1 28 8411 4 4 Operator 0 1
TableEntry Create 1 29 9* 4 4 COCode 0 1
TableEntry Create 1 30 8 8 11 Local 0 8
TableEntry Create 1 31 80 2 64 Operator 0 8
TableEntry Create 1 32 801 4 64 International 0 8
TableEntry Create 1 33 81 9 12 LongDistance 0 8
TableEntry Create 1 34 8101 9 64 AlternateLong 0 8
TableEntry Create 1 35 81800 12 12 TollFree 0 8
TableEntry Create 1 36 81888 12 12 TollFree 0 8
TableEntry Create 1 37 81877 12 12 TollFree 0 8
TableEntry Create 1 38 81900 12 12 Toll 0 8
TableEntry Create 1 39 81976 12 12 Toll 0 8
TableEntry Create 1 40 8911 4 4 Emergency 0 8
TableEntry Create 1 41 8411 4 4 Operator 0 8
TableEntry Create 1 42 8* 4 4 COCode 0 8
TableEntry Create 1 43 *2 6 6 Internal 0 88
TableEntry Create 1 44 22 4 4 WAN 0 22
TableEntry Create 1 45 23 4 4 WAN 0 23
TableEntry Create 1 46 24 4 4 WAN 0 24
TableEntry Create 1 47 26 4 4 WAN 0 26
TableEntry Create 1 48 27 4 4 WAN 0 27
TableEntry Create 1 49 25 4 4 WAN 0 25
TableEntry Create 1 50 28 4 4 WAN 0 28
TableEntry Create 1 51 22 4 4 Internal 0 22
TableEntry Create 1 52 23 4 4 Internal 0 23
TableEntry Create 1 53 24 4 4 Internal 0 24
TableEntry Create 1 54 26 4 4 Internal 0 26
TableEntry Create 1 55 27 4 4 Internal 0 27
TableEntry Create 1 56 25 4 4 Internal 0 25
TableEntry Create 1 57 28 4 4 Internal 0 28
Table Create 2 Incoming 4 Digit DID and Auto At
TableEntry Create 2 1 0 1 1 Internal 0 4
TableEntry Create 2 2 1 4 4 Internal 0 0
TableEntry Create 2 3 2 4 4 Internal 0 0
TableEntry Create 2 4 3 4 4 Internal 0 0
TableEntry Create 2 5 4 4 4 Internal 0 0
TableEntry Create 2 6 500 3 3 Internal 0 3
TableEntry Create 2 7 55 4 4 Internal 0 3
TableEntry Create 2 8 *2 6 6 Internal 0 88
TableEntry Create 2 51 22 4 4 Internal 0 22
TableEntry Create 2 52 23 4 4 Internal 0 23
TableEntry Create 2 53 24 4 4 Internal 0 24
TableEntry Create 2 54 26 4 4 Internal 0 26
TableEntry Create 2 55 27 4 4 Internal 0 27
TableEntry Create 2 56 25 4 4 Internal 0 25
TableEntry Create 2 57 28 4 4 Internal 0 28
Table Create 3 Least Cost Routing
/ Routes
/ Route Description
DestinationRoute Create 1 LocalCO
DestinationRoute Create 2 LocalCONoStrip
DestinationRoute Create 3 Voice Application
DestinationRoute Create 4 Attendant
DestinationRoute Create 5 H323 ConneXtions Ports
DestinationRoute Create 8 8 Pool
DestinationRoute Create 22 VTL Lincoln
DestinationRoute Create 23 VTL New Philly
DestinationRoute Create 24 VTL Marietta
DestinationRoute Create 25 Panama
DestinationRoute Create 26 VTL Quincy
DestinationRoute Create 27 VTL LA Sales Office
DestinationRoute Create 28 Tiffin
DestinationRoute Create 88 Phantom Direct Dialing
/ Route Entry DestinationExtension
DestinationRouteEntry Create 1 1 *0001
DestinationRouteEntry Create 1 2 *0002
DestinationRouteEntry Create 2 1 *0001
DestinationRouteEntry Create 2 2 *0002
DestinationRouteEntry Create 3 1 *0003
DestinationRouteEntry Create 4 1 *0004
DestinationRouteEntry Create 5 1 *0005
DestinationRouteEntry Create 8 1 *0008
DestinationRouteEntry Create 22 1 *0006
DestinationRouteEntry Create 23 1 *0006
DestinationRouteEntry Create 24 1 *0006
DestinationRouteEntry Create 25 1 *0006
DestinationRouteEntry Create 26 1 *0006
DestinationRouteEntry Create 27 1 *0006
DestinationRouteEntry Create 28 1 *0006
DestinationRouteEntry Create 88 1 *0003
/ Route Entry OperId Operation Value
DestinationRouteOperation Create 1 1 1 stripLead 1
DestinationRouteOperation Create 1 2 1 stripLead 1
DestinationRouteOperation Create 8 1 1 stripLead 1
DestinationRouteOperation Create 22 1 1 prepend 10*110*50*20*
DestinationRouteOperation Create 23 1 1 prepend 10*50*50*200*
DestinationRouteOperation Create 24 1 1 prepend 10*70*50*251*
DestinationRouteOperation Create 25 1 1 prepend 10*150*50*251*
DestinationRouteOperation Create 26 1 1 prepend 10*100*50*251*
DestinationRouteOperation Create 27 1 1 prepend 10*80*10*251*
DestinationRouteOperation Create 28 1 1 prepend 10*60*50*251*
DestinationRouteOperation Create 88 1 1 stripLead 2
DestinationRouteOperation Create 88 1 2 prepend 500FAAAAA4#
DestinationRouteOperation Create 88 1 3 append #*F
/ Pretranslators
PreTranslator Create 1 4Digit DDI 4Digit Internal
/ PreTransId Entry Digits
PreTranslatorEntry Create 1 1 1
PreTranslatorEntry Create 1 2 2
PreTranslatorEntry Create 1 3 3
PreTranslatorEntry Create 1 4 4
PreTranslatorEntry Create 1 5 5
PreTranslatorEntry Create 1 6 6
PreTranslatorEntry Create 1 7 7
PreTranslatorEntry Create 1 8 8
PreTranslatorEntry Create 1 9 9
PreTranslatorEntry Create 1 10 0
PreTranslatorEntry Create 1 11 3035
PreTranslatorEntry Create 1 12 3039
PreTranslatorEntry Create 1 13 3058
PreTranslator Create 2 Outbound Caller ID Presentation
PreTranslatorEntry Create 2 1 3
/ PreTransId Entry OperId Operation Value
PreTranslatorOperation Create 1 1 1 replace 4400
PreTranslatorOperation Create 1 2 1 replace 4400
PreTranslatorOperation Create 1 3 1 replace 4400
PreTranslatorOperation Create 1 4 1 replace 4400
PreTranslatorOperation Create 1 5 1 replace 4400
PreTranslatorOperation Create 1 6 1 replace 4400
PreTranslatorOperation Create 1 7 1 replace 4400
PreTranslatorOperation Create 1 8 1 replace 4400
PreTranslatorOperation Create 1 9 1 replace 4400
PreTranslatorOperation Create 1 10 1 replace 4400
PreTranslatorOperation Create 1 11 1 replace 3300
PreTranslatorOperation Create 1 12 1 replace 3200
PreTranslatorOperation Create 1 13 1 replace 3100
/ End of configuration
Michael J Barnett
Telecom/Network Manager
Influent Inc
Dublin Oh 43017
