Aruba Instant firmware can be downloaded either from the in-product update under Maintenance - Firmware; or if that doesn't work, you can create an account on the
Aruba Support Portal and download the firmware from there.
Select your AP model there and it will come up automatically with compatible versions.
Original Message:
Sent: Dec 29, 2020 08:50 AM
Subject: Can I upgrade from Aruba Instant Firmware 6.4.2.3-4.1.1.2_48114 to 6.4.2.6-4.1.3.2_56106?
Hello Clembo, I have a Virtual Controller using 6.4.2.6-4.1.3.2_56106, is there a upgrade for this version ?
If yes, where can I find it ? I'm new in the Aruba environment...
Lucas Girardelli
Original Message:
Sent: Oct 05, 2016 01:25 PM
You can upgrade directly to that or any other version.
