  • 1.  Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 22, 2015 11:08 PM
    Can IAP 205 and IAP 275 at same cluster to upgrade the firmware? Because i did go through the Aruba support portol it was different type of firmware for IAP 205 and 275?
    Please advise.
  • 2.  RE: Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 23, 2015 03:30 AM
    Yes they can join the same cluster. The important thing for this to happen is that they´re operating on the same firmware version when you join them in.
    Cheers,
  • 3.  RE: Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 23, 2015 04:20 AM
    and of course same region
  • 4.  RE: Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 23, 2015 05:55 AM
    Yes , firmware is different because, IAP 275 is Centaurus and IAP 205 is Taurus hardware. in this scenario, either you have to use Airwave for Image upgradation or you have to upgrade the Image manually.
    Please feel free for any further help on this
  • 5.  RE: Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 23, 2015 08:01 AM
    The version number is the only thing that needs to be the same.
  • 6.  RE: Can IAP 205 and IAP 275 at same cluster?
    Posted Mar 23, 2015 08:19 AM
    HI,
    Not only version number, all the following should match,
    1. Image code version
    2. VLAN should be same
    3. Country code
