Can Use Omni Antenna mesh with Directional Antenna
  • 1.  Can Use Omni Antenna mesh with Directional Antenna
    Posted Oct 07, 2010 10:16 AM
    My customer give me a question, can we use Omni directional antenna mesh with Directional antenna?
  • 2.  RE: Can Use Omni Antenna mesh with Directional Antenna
    Posted Oct 07, 2010 10:30 AM
    Yes, antennas may be 'mixed' together, this is a typical application for
    point to multi-point Mesh. The link budget of the Mesh link(s) should
    be calculated and the antenna patterns considered as per normal
    best-practices engineering for all RF deployments.
    FYI, a given Mesh link may be monitored for Link Quality from the Aruba
    Controller under Monitoring/Mesh Nodes/Topology. There you will be
    able to view the Link Quality metric of the mesh link in real-time.
  • 3.  RE: Can Use Omni Antenna mesh with Directional Antenna
    Posted Oct 07, 2010 11:16 AM
    Thanks...
