  • 1.  Cannot BULK create PEAP Account on APs in Central for AP1X PEAP om Uplink
    Posted Feb 14, 2025 09:21 AM
    I seem to have stumbled on a "idocracy" in Aruba Central. I have a Group with about 400 APs using the Group config for everything except the AP-name.
    We are now planning to enable and run 802.1x PEAP (AP1X PEAP) on the AP uplink to improve security in out wired network.
    I cannot find a way to bulk create the PEAP account to use for AP authentication on all 400 APs as a group setting.
    Since I know its a pre-env variable like the AP-name, I would expect I could mark all APs, and click edit. But that does not give me any options for settings the PEAP user.
    Can it really be true I have to edit ALL APs individually to setup that account?? It will take ages.....
  • 2.  RE: Cannot BULK create PEAP Account on APs in Central for AP1X PEAP om Uplink
    Posted Feb 14, 2025 10:41 AM
    If you want to accomplish that task through the current Central UI, yes, that's what is required.  Other option is to edit using API.
    https://central.wifidownunder.com/workflow-csv.html has a workflow available for accomplishing this task.
    Carson Hulcher, ACEX#110
  • 3.  RE: Cannot BULK create PEAP Account on APs in Central for AP1X PEAP om Uplink
    Posted Feb 14, 2025 11:01 AM
    Bummer.... Guess I'll have to take a look at the API approach....
  • 4.  RE: Cannot BULK create PEAP Account on APs in Central for AP1X PEAP om Uplink
    Posted Feb 16, 2025 08:37 AM
    API could be an avenue to pursue.
  • 5.  RE: Cannot BULK create PEAP Account on APs in Central for AP1X PEAP om Uplink
    Posted Feb 17, 2025 03:28 AM
    Edited by oden74 Feb 17, 2025 03:29 AM
    Another option could be to use EAP-TLS with the built in factory certificate in the TPM on the AP.
    https://www.youtube.com/watch?v=5QjUix9yL1U&t=4s
