Thanks for the prompt reply. Please find the answers in italics.
What authentication type are you using for your wireless network?
I have two SSIDs:
1. wpa2-psk-aes (hidden)
2. opensystem
I would think the issues you're experiencing are due to your pc not being connected correctly (or at all) to the network.
I don't think so. When I reverted back to the previous version, my desktop automatically connects to the network when the wifi went live.
Do you have a backup of the configuration pre-upgrade? If possible, you could compare it to a current one to see if something is different
Yes. That's what I did to see if there are post-upgrade settings that were automatically done. The previous config settings and new config settings are the same.
Ariel
