  • 1.  Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 06:24 AM
    Hi everyone.
    I'm trying to convert IAP-93 to Mobility Controller (650) with the Maintenance tab, but the conversion stops with the error:
    Could anyone help me to diagnose and solve the problem?
    The log is attached below.
    Attachment(s)
    txt
    log.txt   27 KB 1 version
  • 2.  RE: Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 06:40 AM
    It seems you are trying to convert the IAP-93 to a RAP and want to terminate it on 620 Controller ? what do you want to do you want to convert IAP to RAP or IAP to Campus AP ?
    Please clarify the above I can help you on this.
  • 3.  RE: Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 06:43 AM
  • 4.  RE: Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 07:56 AM
    Oh, the situation seems clear now.
    I tried to convert the IAP to RAP and my goal was to convert it to Campus AP.
    Thanks for help.
  • 5.  RE: Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 11:06 AM
    To achieve this Code version also important . which code you are using in 6XX controller and IAP ?
  • 6.  RE: Can't convert IAP-93 to Mobility Controller
    Posted May 18, 2015 11:20 AM
    The conversion to Campus AP was fine.
    Version of code on Controller 650 is 6.4.2.2
    I don't know the version of InstantOS on IAP-93, it's already converted.
    Thanks for help.
