Network Management
  • 1.  Can't upgrade firmware on 2930F switches
    Posted Jul 23, 2024 07:02 PM
    Edited by t.antony Jul 23, 2024 07:07 PM
    I'm trying to upgrade firmware on the 2930F switches, like I've always done, but this time I keep getting this error.
    I tried different switch, but same error.  I downloaded the file from official Aruba firmware page (https://networkingsupport.hpe.com/downloads), like I've always done.
    All my 2930F switches have the same version, WC.11.0018, and I'm trying to upgrade them to WC.11.0020.
    I'm downloading the WC_16_11_0020.swi file.
    I also tried WC.11.0019, but that also brings the same error.
  • 2.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 23, 2024 07:04 PM
    According to the release notes, there's no changes from 0018 to 0020, but it still should let me upgrade right?
    Never had this issue before.
    https://www.arubanetworks.com/techdocs/AOS-Switch/RN/16.11/AOS-SSwitch16.11.0020RN.pdf
  • 3.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 23, 2024 07:10 PM
    Edited by t.antony Jul 23, 2024 07:12 PM
    Correction, there is that on the PDF, and I'm using the webui because that's what I always used.  And it says to use a CLI command, but do I need to have a tftp server for this?
    It looks like this is for upgrading from 0018 to 0019, but I'm going from 0018 to 0020
  • 4.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 23, 2024 08:14 PM
    Ok I figured it out.  I downloaded the free SolarWinds TFTP server, and used this command and reboot the switch.
    copy tftp flash 10.0.0.166 "WC_16_11_0020.swi" primary
  • 5.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 23, 2024 08:58 PM
    I was able to update 7/9 switches using the command, but 2 of the switches are showing this below and can't update.
    Server returned error 1024.  Wrong block number.
  • 6.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 24, 2024 08:24 AM
    TFTP can be a bit unreliable... if there is a lower MTU somewhere in the path between the client and server, it may not work or work unreliable. Are there possibly a lot of switches (or a firewall/router/WAN) in between the switches that fail and your TFTP server?
    If you have a sftp server (SSH), you may try to copy it from there.
  • 7.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 24, 2024 09:08 AM
    No, not a lot of switches or anything between those 2 switches that failed.
    I was able to upgrade from cli switches that were uplinks from the 2 failed.
    May be I'll try connecting a laptop directly to those 2 switches to see if it works.
  • 8.  RE: Can't upgrade firmware on 2930F switches
    Posted Jul 24, 2024 12:31 PM
    I used tftpd64 and I was able to update the 2 switches using that.
    https://bitbucket.org/phjounin/tftpd64/downloads/
