Original Message:
Sent: Jul 24, 2024 09:07 AM
Subject: Can't upgrade firmware on 2930F switches
No, not a lot of switches or anything between those 2 switches that failed.
I was able to upgrade from cli switches that were uplinks from the 2 failed.
May be I'll try connecting a laptop directly to those 2 switches to see if it works.
Original Message:
Sent: Jul 24, 2024 08:24 AM
TFTP can be a bit unreliable... if there is a lower MTU somewhere in the path between the client and server, it may not work or work unreliable. Are there possibly a lot of switches (or a firewall/router/WAN) in between the switches that fail and your TFTP server?
If you have a sftp server (SSH), you may try to copy it from there.
Original Message:
Sent: Jul 23, 2024 08:58 PM
I was able to update 7/9 switches using the command, but 2 of the switches are showing this below and can't update.
Server returned error 1024. Wrong block number.
Original Message:
Sent: Jul 23, 2024 08:14 PM
Ok I figured it out. I downloaded the free SolarWinds TFTP server, and used this command and reboot the switch.
copy tftp flash 10.0.0.166 "WC_16_11_0020.swi" primary
Original Message:
Sent: Jul 23, 2024 07:02 PM
I'm trying to upgrade firmware on the 2930F switches, like I've always done, but this time I keep getting this error.
I tried different switch, but same error. I downloaded the file from official Aruba firmware page (https://networkingsupport.hpe.com/downloads), like I've always done.
All my 2930F switches have the same version, WC.11.0018, and I'm trying to upgrade them to WC.11.0020.
I'm downloading the WC_16_11_0020.swi file.
I also tried WC.11.0019, but that also brings the same error.
