CAP bridge-mode SSIDs keepalive timer
  • 1.  CAP bridge-mode SSIDs keepalive timer
    Posted Oct 11, 2012 11:49 AM
    In the official documentation :
    For both RAPs and CAPs, tunneled SSIDs will be brought down eight (8) seconds after the AP detects that there
    is no connectivity to the controller. For CAP bridge-mode SSIDs, the CAP will be brought down after the
    keepalive times out (default 3.5 minutes). RAP bridge mode SSIDs are configurable to stay up indefinitely
    (always-on / persistent).
    Does it mean that a briged session can stay up even if the controller is unreachable ? I did a test and I lost the connectivity even in bridge mode. So it's seems that the 3.5 minutes dont worked for me.
    Where can I see that keepalive setings ?
    Thanks !
  • 2.  RE: CAP bridge-mode SSIDs keepalive timer
    Posted Oct 11, 2012 01:12 PM
    As far as I know, you can only set the SSID to stay up on a RAP if the controller is lost.  You do that by setting "remote-ap operation" to persistent" on the virtual ap profile.
