I'm using DHCP option 43 to discover controller but this AP seems to be ignoring it (I restarted AP by bouncing switchport & PoE).
Original Message:
Sent: Jul 10, 2024 03:38 PM
Subject: CAP somehow changed to IAP by itself, how to change it back?
What controller discovery mechanism are you using? Do you have discovery via DNS or DHCP setup already? If not, try one of those to get the IAP to reattach.
https://www.arubanetworks.com/techdocs/ArubaOS_8.10.0_Web_Help/Content/arubaos-solutions/access-points/enab-ctrl-disc.htm
Original Message:
Sent: Jul 10, 2024 12:39 PM
I have six AP-535s on a switch (actually a 2x Cisco SW stack and APs are dual-connected), all APs are Campus APs managed by Mobility Conductor 7205 with ArubaOS 8.10.0.7.
I don't know what happened, but one AP suddenly disappeared from controller and started creating weird things on a switch (first port-security, once disabled it triggered BPDU guard), so I enabled only one switchport.
I noticed on a switch that this one particular AP somehow became Instant AP:
PCNTRN_9300_V5_STACK#show lldp nei g1/0/5 det------------------------------------------------Local Intf: Gi1/0/5Chassis id: 482f.6bc3.3336Port id: 482f.6bc3.3336Port Description: eth0System Name: 48:2f:6b:c3:33:36System Description: ArubaOS (MODEL: 535), Version Aruba IAPTime remaining: 115 secondsSystem Capabilities: B,WEnabled Capabilities: WManagement Addresses: IP: 10.94.2.15
Is this normal behavior? The controller was always available and all other APs with the same configuration operate normally, just this one AP misbehaved and I have no idea why..
The question is - how to convince this unwanted Instant AP to become Campus AP again and join the controller?
It is pingable from the controller and I tried to SSH into it with admin/admin, admin/serialnumber, admin/SERIALNUMBER, admin/macaddress, admin/ma:ca:dd:re:ss, admin/maca.dress but all options gave me wrong credentials. It's not easily accessible and I'm not sure I even have supported console cable for it so I would prefer some "remote" solution if it exists.
I am new to Aruba so any help and guidance is really appreciated.
Thank you!
Jaroslav
