Captive portal and MAC authentication
This thread has been viewed 19 times
  • 1.  Captive portal and MAC authentication
    Posted Apr 02, 2013 07:09 AM
    It looks like I have an issue when I'm creating a Guest WLAN and using the captive portal.
    I would like to "bypass" this portal for specific MAC addresses.
    I have enabled the option, added the mac@ as username & password, but i still have the portal page.
    Also, do you know if it is possible in this portal to only include the banner ? without the email field ?
    Thank you very much.
  • 2.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 07:20 AM
    In order to give to spesefic mac address to ability to bypass captive portal pages,u should enbale user deviertion roles in your AAA profile.
    here is an example:
    Please read the following post:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Single-Click-Captive-Portal/m-p/66488#M7800
    (it's contain all u need to know regarding captive)
    Also read this post:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Captive-Portal-Login-page-quot-Login-in-1-Click-quot-template/m-p/61172/highlight/true#M7230
  • 3.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 07:24 AM
    Thank you for your quick answer, unfortunately I'm running on IAP-105 without controller.
    Thus, I don't have all these settings,
    This is what it looks like:
  • 4.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 07:50 AM
    Please search the support knowledgebase here:  http://support.arubanetworks.com/KNOWLEDGEBASE/tabid/133/Default.aspx for mac authentication instant.
    One article I pulled up in the search is here:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1471
  • 5.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 08:33 AM
    Again thank you, this article is exactly what I'm looking for:
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-do-I-configure-Captive-Portal-with-MAC-authentication-on-an-SSID-in-Aruba-Instant
    Unfortunattely, I'm not able to choose the "Enforce MAC auth only role" in the role based access role.
    The only option I have are "Network Based" or "Unrestricted". ( I'm using the internal database).
    It looks like this option is only there when I use an external database server.
  • 6.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:03 AM
    What InstatOS version are u using? (U must use version 3.2 or higher to enable those feauters)
    Also...
    I attached for u the userguide (Please read from page 139)
    Attachment(s)
  • 7.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:05 AM
    I'm using 6.2.0.0-3.2.0.2_37229.
  • 8.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:09 AM
    Did u notice this:
  • 9.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:11 AM
    Also , please take a look on older post i wrote for someone:
    http://community.arubanetworks.com/t5/Authentication-and-Access/White-list-for-MAC-addresses/td-p/65242
    *Contain a working method*
  • 10.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:22 AM
    Well the second method is working properly, but it doesn't really match what I'd like to do.
    1 SSID: - A captive portal with legal notice for users (without auth.)
                   - unrestricted access with mac @ for printers, ...
    I guess the only way to do this is to go with a radius, or to user 2 diffrent SSID.
  • 11.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:23 AM
    Yep,
    As far as the userguide... and as far as i know.
  • 12.  RE: Captive portal and MAC authentication
    Posted Apr 02, 2013 09:25 AM
    Again, thank you very much.
    I'm really impressed by the quickness of this community !
  • 13.  RE: Captive portal and MAC authentication
    Posted Jun 24, 2014 11:16 AM
    Thank you so much for this detailed description.
    It worked smoothly :smileyhappy:
