Getting a public certificate is the solution and workaround at the same time.
Teaching users to 'accept risk and proceed' is something you should avoid at all costs, as when they see a warning next time, they will 'accept risk and proceed' and get infected with ransomware or worse.
Certificates are pretty affordable these days.
Original Message:
Sent: Sep 09, 2021 06:59 AM
Subject: Captive portal certificate issue with Android/Web browsers
I currently implemented a captive portal through our mobility master (no clear pass currently). The problem we are having is that when users are connecting to the test captive portal SSID, some android users/ laptops using chrome,edge,firefox receive a certificate invalid issue. The fact that the certificate warning is displayed is not the problem so long that we can still "accept the risk and proceed" however I've ran into the problem that some browsers will not give users the option to proceed.
I believe the correct solution to this is to get a public CA approved Certificate.
However, Is there any work around or anything that I could do on the mobility master as a temp fix? Thanks in advance!
Alex Pilkerton
