If you have a captive portal in your firewall, which seems to be the case, just create an open/PSK/other SSID with an allowall policy and let the external firewall handle the captive portal.
Your configuration appears to enable the captive portal in the controller, in which case I don't see the relation to a fortigate.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 13, 2025 01:53 AM
Subject: Captive Portal Doesn't Popup .Configured LDAP in Fortigate
Dear all
I have configured LDAP in Fortigate to authenticate users with Google email and created SSIDs in the Aruba Controller. However, the captive portal isn't popping up for some reason. Are there any documents available for configuring the captive portal? I can share some screenshots if anyone finds a mistake or has relevant documents to share.
