  • 1.  Captive portal redirection with port 4343
    Posted Jul 31, 2024 04:19 AM
    Hi All, I am using Aruba IAP version 8.10.
    I'm in the process of learning CPPM captive portal(CPPM version is 6.10)
    With the guide from Airheads Broadcasting youtube series Aruba ClearPass Workshop (2021) - Guest Access #3 - Wireless Guest (finishing up)
    I found that my captive portal redirection always contain port 4343 instead of the configured port 443.
    Captive portal doesn't show up.
    Need help on this.
  • 2.  RE: Captive portal redirection with port 4343
    Posted Aug 01, 2024 04:00 AM
    Port 4343 is for the WebUI of your WLAN (AP/controller). So it looks like whatever is under the blue box (IP or hostname) is pointing to your AP/VC/controller, and not to ClearPass; or ClearPass is not excluded from the redirection.
    There is a video on guest server vs controller initiated that shows how to debug the captive portal process step by step with the browser developer tools. That may be a good one to have a look at.
  • 3.  RE: Captive portal redirection with port 4343
    Posted Aug 01, 2024 04:09 AM
    Hi Herman,
    Thanks for you great video.
    I changed the guest vlan, make the guest IP address reachable to CPPM server now.
    Can I conclude that the Guest IP subnet have to be reachable with CPPM Server?
    Thank you.
  • 4.  RE: Captive portal redirection with port 4343
    Posted Aug 01, 2024 04:33 AM
    yes.  you can also enable "automatic URL allowlisting"
