Some items to cover when considering wall mounting APs:
- Most APs with integrated antennas are optimized for ceiling mount, meaning that RF range will be best when the AP is mounted that way. If range is critical, mounting these APs vertically is not ideal
- If range is a concern and ceiling mount not an option, you can either: (1) use a mount accessory that positions the AP horizontally, (2) use and AP that supports external antennas in combination with simple dipole "stick" antennas, or (3) use an AP that's optimized for wall (vertical) mount, like the AP-93H
- Cabling (network and power). When wall mounting an AP, it may be possible to take advantage of existing cabling by attaching the AP to an electrical/data wall box. The AP-93H is specifically designed to support this, but mount kits for several other AP models can be used for this as well.
- Security (anti-theft). The requirements and options to mount an AP securely may be affected by the choice of mount location. Many mount kits have some form of basic built-in security. In the cae of the AP-93H this is integrated: the AP uses a secure screw to permanently attach to the mount plate
