Cloud Managed Networks
Central 2.5.3/AOS-CX - Uploading the certificate for DUR using the Multi-Editor
  • 1.  Central 2.5.3/AOS-CX - Uploading the certificate for DUR using the Multi-Editor
    Posted Apr 08, 2021 01:15 PM
    Here is a video on uploading the trusted cert to a CX switch for use with downloadable user roles using the Multi-Editor in Central 2.5.3.  Make sure to copy the entire config as it would appear in the switch configuration including the "end of cert" messages.
    Justin Noonan
