Cloud Managed Networks
  • 1.  Central and Uplink module port numbering
    Posted Feb 09, 2019 03:34 AM
    I want to manage a 2930M with a 4-port SFP+ uplink module. But it seems Central cannot handle the extra ports.
    1. I added a VLAN und configured the switchports 51-52 as tagged. The VLAN is created on the switch, the tagging is not configured.
    2. I configured a trunk with port 51-52 via Central. No configuration appears on the switch.
    If I repeat these tasks with switchport 1+2, there is no problem, tagging is right and trunking works fine.
    Is this maybe a problem with the numbering, 49-52 in Central, but A1-A4 on the switch itself.
    Any ideas how to resolv the bug or am I doing something wrong?
    Best regards,
    Rene
  • 2.  RE: Central and Uplink module port numbering
    Posted Feb 11, 2019 09:28 PM
    I'm afraid this use case still requires template-based configuration.
  • 3.  RE: Central and Uplink module port numbering
    Posted Feb 12, 2019 02:31 AM
    Thx for your reply. I suspected this.
    Because this way of administration is not suitable for the customer, is there a way to just configure some ports (only uplinks) via template and the access ports via individual configuration via GUI? (no GUI groups)
    Best regards,
    Rene
  • 4.  RE: Central and Uplink module port numbering
    Posted Mar 25, 2019 04:54 AM
    Hi Rene,
    did you find a solution for this problem?
  • 5.  RE: Central and Uplink module port numbering
    Posted Mar 25, 2019 07:09 AM
    Not yet
