Cloud Managed Networks
Central AOS 8 - 80Mhz wide 6Ghz channels also defaults it for 5Ghz
  • 1.  Central AOS 8 - 80Mhz wide 6Ghz channels also defaults it for 5Ghz
    Posted 29 days ago
    I want to use 80Mhz wide channels for our 6Ghz radios so I am only setting it up for the 6Ghz radio in the ARM profile and leaving the 5Ghz radio to 20Mhz.
    The issue is that the 5Ghz radio for some reason is also at 80Mhz even though it is not checked off.
    In AOS 10 this is not an issue but in AOS 8 Instant it seems to be?
    Running 8.10.0.13. AP-635s
    Aruba Partner Ambassador ACMP, ACDP, ACCP, ACEP
  • 2.  RE: Central AOS 8 - 80Mhz wide 6Ghz channels also defaults it for 5Ghz
    Posted 29 days ago
    There are two options in Central. Both are located in Devices > Config > Radio > RF > ARM > Access Point Control.
    1. Check "Customize Valid Channels" and remove 5 GHz channels with +, E, or S affixes. These are for 40, 80, and 160 MHz channel widths respectively.
    or
    2. Uncheck "Wide Channel Bands" from 5 GHz.
  • 3.  RE: Central AOS 8 - 80Mhz wide 6Ghz channels also defaults it for 5Ghz
    Posted 27 days ago
    "Wide Channel Bands" is not checked for 5Ghz... only 80Mhz for 6Ghz is.
    I guess I have to manually remove the + and E channels so that they don't work and give that a shot
  • 4.  RE: Central AOS 8 - 80Mhz wide 6Ghz channels also defaults it for 5Ghz
    Posted 27 days ago
    That worked by manually removing the channels
