Wired Intelligent Edge
Central Switch Help
  • 1.  Central Switch Help
    Posted Oct 23, 2019 09:26 PM
    Need help getting my 2930F in central. I have an AP345 and 2930F on the same network and my AP shows online but my switch shows offilne (Although oddly it has a green dot in device inventory). Both have been added with serial/mac and licenses applied.
    Switch has basic config static IP, NM, GW, and DNS with very little other config. Is there something I'm missing? Activate isn't required is it as I assume this is for ZTP only. I read somewhere that "device.arubanetworks.com" needs to resolve but that doesn't seem to be accessible as you can see below.
    Aruba-2930F-8G-PoEP-2SFPP# ping google.com
    google.com is alive, time = 55 ms
    Aruba-2930F-8G-PoEP-2SFPP# ping yahoo.com
    yahoo.com is alive, time = 78 ms
    Aruba-2930F-8G-PoEP-2SFPP# ping device.arubanetworks.com
    Request timed out.
  • 2.  RE: Central Switch Help
    Posted Oct 24, 2019 12:03 AM
    Hi daflava190,
    Activate is important for all devices to connect to central, as activate will send the information to each device, which central instance is the correct one.
    But as tested by myself while writing this, activate is not reachable. I think there is some maintenance going on. We should wait until Activate is reachable again and then you should check the output of
    show activate provision
  • 3.  RE: Central Switch Help
    Posted Oct 24, 2019 08:31 AM
    Not sure I follow here, so an AP can instantly get into central without activate when I put in serial/mac as that's what i've done but a switch has to use activate although serial/mac is in central? I went to activate and only option for switch is to airwave and even with that I'm not sure how I'd tell activate to push my device to central since I can't use IP or DNS.
    For show activate provision no key would show without "activate provision force" even after reboots etc. I see this as a problem if activate has issues and I can't just put things in central which is online. Also shoudl I not be able to ping device.arubanetworks.com?
    Aruba-2930F-8G-PoEP-2SFPP# show activate provision
    Configuration and Status - Activate Provision Service
    Activate Provision Service : Enabled
    Activate Server Address : device.arubanetworks.com
    Activation Key : YRGSAUVL
    Aruba-2930F-8G-PoEP-2SFPP# show aruba-central
    Configuration and Status - Aruba Central
    Server URL : None
    Connected : No
    Mode : NA
    Last Disconnect Time : NA
    Request timed out.
    Aruba-2930F-8G-PoEP-2SFPP# ping arubanetworks.com
    arubanetworks.com is alive, time = 71 ms
  • 4.  RE: Central Switch Help
    Posted Oct 24, 2019 03:05 PM
    hi daflava190,
    The switch is able to communicate to activate successfully. You know, because the switch has a Cloud Activation Key:
    Are you sure, the switch is added to your central account? Does the switch has a valid subscription?
    What does the log of the switch is telling you?
  • 5.  RE: Central Switch Help
    Posted Oct 24, 2019 09:47 PM
    So turns out my major issue was I added a different switch serial/mac and didn't realize so the switch I was bringing up wouldn't get to central because it wasn't in central...
    I do have one other issue I'm trying to solve switch related, best practice would be not to use VLAN 1 but when I make a VLAN like 10 for example and set it to "ip address dhcp-bootp" as I'd like it to be assigned from my router than statically assign it never gives the default gateway or DNS unless its on VLAN 1.
    Examples (MGMT = VLAN 10)
    2930F-01(config)# show ip
    Internet (IP) Service
    IP Routing : Disabled
    Default Gateway : 192.168.1.1
    Default TTL : 64
    Arp Age : 20
    Domain Suffix : routerlogin.net
    DNS server : 192.168.1.1
    | Proxy ARP
    VLAN | IP Config IP Address Subnet Mask Std Local
    DEFAULT_VLAN | DHCP/Bootp 192.168.1.41 255.255.255.0 No No
    MGMT | DHCP/Bootp
    LAN_WLAN | Disabled
    Default Gateway :
    Default TTL : 64
    Arp Age : 20
    Domain Suffix :
    DNS server :
    | Proxy ARP
    MGMT | DHCP/Bootp 192.168.1.41 255.255.255.0 No No
    LAN_WLAN | Disabled
    Also it seems that when I assign port 1 and port 8 in VLAN 10 both untagged which should be standard access port I don't get DHCP to a device although the router is doing DHCP in the VLAN, only works in VLAN 1. I feel like I'm completely missing something here!
  • 6.  RE: Central Switch Help
    Posted Oct 24, 2019 11:37 PM
    can share the port config of the port, where the router is connected to? Does this port is also configured for VLAN 10 untagged?
  • 7.  RE: Central Switch Help
    Posted Oct 25, 2019 07:10 AM
    Router on port 1 doing DHCP for MGMT, AP port 7 doing DHCP for everything else, Client on port 10 (although I've moved ports around untagged) Idea is to get everythign off VLAN1, put switch/AP/router on MGMT VLAN 10 allwoing router to do DHCP and eventually rest of the switch will be on VLAN 20 LAN_WLAN with AP doing DHCP.
    hostname "2930F-01"
    module 1 type jl258a
    aruba-central disable
    include-credentials
    password manager user-name "admin" sha1
    "9df3343f45e54709985a1dbf1aa2b3a895fd5537"
    snmp-server community "public" unrestricted
    snmpv3 engineid "00:00:00:0b:00:00:38:21:c7:b9:46:20"
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1,6-10
    untagged 2-5
    ipv6 enable
    ipv6 address dhcp full
    exit
    vlan 10
    name "MGMT"
    untagged 1,7,10
    tagged 8-9
    exit
    vlan 20
    name "LAN_WLAN"
    untagged 6,8-9
    tagged 7
    no ip address
    exit
    allow-unsupported-transceiver
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
  • 8.  RE: Central Switch Help
    Posted Oct 25, 2019 01:30 PM
    Ok, so client, AP, switch and router are all in VLAN 10 and the client, nor the AP is getting an IP from the router? correct?
  • 9.  RE: Central Switch Help
    Posted Oct 25, 2019 01:35 PM
    Correct essentially I'm just trying to get everything of VLAN 1 to VLAN 10 using DHCP from my router which will live on VLAN 10 as well. The AP and any client like a laptop will get an IP, GW, and DNS but the switch itself will only get an IP in VLAN 10 but no GW/DNS server so that's an issue with me using VLAN 10 connecting up to an ISP in this case an LTE router giving a DHCP address.
  • 10.  RE: Central Switch Help
    Posted Oct 25, 2019 07:58 PM
    So I spent almost all day with TAC, two seperate engineers. Neither could really say if this should be a possibility to populate GW/DNS if not using VLAN1. Took packet captures from both VLAN 1 and 10 and both show my DHCP server issuing options 3 and 15 which are router/DNS settings only VLAN 1 takes these. They are shooting these logs up to engineering it seems. Guess update if they find something....
  • 11.  RE: Central Switch Help
    Posted Oct 28, 2019 12:45 AM
    That's really strange, as, from my point of view, this should happen in every VLAN. But one thing came into my mind. Did the switch support this command:
    management-vlan 10
  • 12.  RE: Central Switch Help
    Posted Oct 28, 2019 04:25 AM
    same idea like florian about management vlan...
  • 13.  RE: Central Switch Help
    Posted Oct 28, 2019 08:38 AM
    "management-vlan 10" did work on the switch but still no GW/DNS
    Default Gateway :
    Default TTL : 64
    Arp Age : 20
    Domain Suffix :
    DNS server :
    | Proxy ARP
    VLAN10 | DHCP/Bootp 192.168.1.40 255.255.255.0 No No
  • 14.  RE: Central Switch Help
    Posted Oct 28, 2019 01:16 PM
    Need don't have a management vlan X
    from the display, there is a no default gateway
    what do you have with show ip route ?
  • 15.  RE: Central Switch Help
    Posted Oct 28, 2019 04:13 PM
    TAC finally came back, wish they would have known this from the two different engineers and 8hrs of troubleshooting as it's something simple.
    Resolved by doing "primary-vlan VLAN-ID"
  • 16.  RE: Central Switch Help
    Posted Oct 29, 2019 12:49 AM
    this was my second thought but management VLAN popped up before that.
  • 17.  RE: Central Switch Help
    Posted Aug 14, 2020 08:51 AM
    is that "primary vlan VLAN-ID" done on CLI or on Central gui? I also need to onboard switches not using vlan1  as connection to central
    Anyone has a how to?  Better with template or with a cli snippet?
  • 18.  RE: Central Switch Help
    Posted Sep 09, 2020 04:38 AM
    still searching how to activate another vlan as primary from central without loosing the central connection or config, in central is the option not available
  • 19.  RE: Central Switch Help
    Posted Oct 07, 2020 07:04 AM
    Last Central update includes the option for primary vlan in GUI
