Cloud Managed Networks
  • 1.  Central Template Groups - Yes or No?
    Posted 20 days ago
    I'm doing a PoC of Central right now.  20 year Aruba customer and have used all their other products.  Just recently logged into Central for basically the first time and have been navigating around.   I am primarily interested in getting my CX and AOS switches moved to Central.  I watched a few YT videos and they primarily show switches being managed with variables and template groups (TG).
    My account team is recommending against TG because the migration to NextGen Central does not support TGs.  I would just like to get the groups opinion on the best method to manage switches in Central.  Any other things you would do different from naming standards, organization, etc....
  • 2.  RE: Central Template Groups - Yes or No?
    Posted 20 days ago
    I would follow the Validated Solution Guides as a best-practice.
    If template groups meet your requirements best, I don't see an issue using them for now. With the new configuration model, things indeed change, but also change from gui config; at one point in time you may need to convert your configuration anyway. If you need to design/setup a very large/complex network, and days/weeks/months will go in the rollout/testing, it may be good to work with your local account team and see what is wise to do at this moment and how to make sure that investments you do now in the configuration can be reused as much as possible in the future.
