  • 1.  Centralized Airgroup
    Posted Oct 16, 2019 04:31 AM
    Helle Airheads,
    In my enviroment we run a Mobility Master solution (ArubaOS 8.5.0.2)  where we have our customers MD controllers installed.
    Each customer have their own group under Managed Network to manage configuration per customer.
    My problem comes when configuring Airgroup.
    We have tried running distributed mode which never really went well. Some services seem to work, while others don't.
    After hours of trying to debug Airgroup we decided to switch to Centralized mode.
    This is working much better. All services seem to be distributed to clients. But with success comes new problems.
    Customer A can now see Customer B's Airgroup Servers and vice versa. They cannot connect to them, as the network is segmented. So this is only a visual thing.
    Is there a way to automatically segmentate a server once it's discovered by Airgroup?
    I have found the "Server-Based Policy" where I am able to set rules per server. I want a more general setting.
    It doesn't matter if it's segmented by AP neighbor hops or by AP group or User Role. It's just a matter of not being able to see other customers Airgroup servers.
    Does anyone know if I will be able to achieve this in Centralized mode?
  • 2.  RE: Centralized Airgroup
    Posted Oct 16, 2019 08:11 AM
    Create AirGroup domains
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Centralized Airgroup
    Posted Oct 16, 2019 08:19 AM
    Hello Victor,
    From my understanding Airgroup Domains are not possible when running centralized mode. Have I misunderstood this?
    showing status on the controller shows N/A at the active domain:
    Showing AirGroup info from /md
    AirGroup Information
    Feature Status
    AirGroup mode Centralised
    AirGroup Profile default-AirGroup
    CPPM Profile
    Active domain N/A
    MDNS Enabled
    DLNA Enabled
    Enforce Registration Disabled
    IPV6 Disabled
    AirGroup Service Information
    Service Status
    default-airprint Enabled
    default-airtame Enabled
    default-sonos Enabled
    default-googlecast Enabled
    default-airplay Enabled
    default-dial Enabled
