Centralized Licensing
  • 1.  Centralized Licensing
    Posted Nov 01, 2013 09:57 AM
    The 6.3 User Guide states the following:
    "New licenses can be added to any controller managed by a centralized licensing system, although best practices recommends adding them to the primary licensing server, for easier management and tracking of licenses across a wide network. Licenses can only be deleted from the controller on which the license is installed."
    So, in a typical master-local setup with master/master-backup redundancy using VRRP and the master controller acting as the primary licensing server, is there any benefit ("easier management and tracking of licenses across a wide network") to first doing a license transfer of all transferable licenses from the locals to the primary master?
  • 2.  RE: Centralized Licensing
    Posted Nov 01, 2013 10:14 AM
    That works
  • 3.  RE: Centralized Licensing
    Posted Nov 01, 2013 04:11 PM
    I would say leave it as is.  They will all be part of the aggregate pool.  However, if any controllers are being upgraded or replaced, then I would transfer those...
