  • 1.  Centralized Licensing
    Posted Nov 20, 2014 01:29 PM
    I've configured VRRP on both of my controllers (7220s) and after testing the failover, everything works fine.
    I go try to configure centralized licensing by inputing the licensing server IP which is the VIP/aruba-master dns entry (the peer address of the standby controller was already populated) and I receive the following error:  Master redundancy is configured. To configure License server redundancy, please disable the master redundancy.
    How can I configure centralized licensing while keeping my VRRP configuration?
  • 2.  RE: Centralized Licensing
    Posted Nov 20, 2014 02:11 PM
    That error message should be removed, because it is misleading.  You just need to enable Centralized Licensing, and you're done with your setup.
  • 3.  RE: Centralized Licensing
    Posted Nov 20, 2014 02:21 PM
    Thanks.
