  • 1.  Centralized Licensing
    Posted Jun 28, 2016 02:07 PM
    Looking at enabling Centralized Licensing and everything looks as simple as a check mark.  Running a Master/Local pair of 7210 devices.
    I have been use to purchasing 1 of each license for the controllers and keeping things balanced is that needed or can things be unbalanced?  Is there a limit on the number of licenses I know the 7210 only supports 512 total for APs is 256 of each for both the max?
  • 2.  RE: Centralized Licensing
    Posted Jun 28, 2016 02:16 PM
    When you enable centralized licensing, any licenses you installed on any controller will be pooled.  You can install more licenses than the platform limit for the master and they will be redestributed.
