  • 1.  Centralized licensing AOS 6.3
    Posted Aug 07, 2013 11:59 AM
    I have a customer with a mix of 3400 and 3400-32 (with built-in licenses) who want to move to AOS 6.3 and
    centralized licensing.
    As mentioned in the release notes for 6.3 the built-in licenses are not shared to the licensing server.
    Is there any way to export the built-in licenses to add them to the license server ?
    Thanks and kind regards
    Christian
    #3400
  • 2.  RE: Centralized licensing AOS 6.3
    Posted Aug 07, 2013 01:29 PM
    You will NOT be able to add or merge any controller built-in license or controller box specific license like PEF-V to the licensing server. Licensing server takes care and fetches the licenses to the controllers to manage effectively however they wont look or take care of controller built-in licenses.
    Hope this helps. Thank you.
  • 3.  RE: Centralized licensing AOS 6.3
    Posted Aug 07, 2013 01:33 PM
    To add to this...if a controller has built in licenses and is part of a centralized licensing deployment, the APs terminating on that controller will consume the BUILT-IN licenses FIRST vs. the pooled licenses.
